It is currently Fri Aug 15, 2025 12:45 pm
 Post subject: Adjustable saddles?
PostPosted: Tue Nov 25, 2014 8:02 pm
Does anyone have any experience building bridges with adjustable saddles? Any pics available?
 Post subject: Re: Adjustable saddles?
PostPosted: Tue Nov 25, 2014 9:02 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Kevin Pederson developed a design for an adjustable saddle, which he patented.
Adjustability was back and forth, for intonation, not up and down to alter action.
PostPosted: Wed Nov 26, 2014 12:50 pm
adjustable saddles are often used on lower end instruments.
PostPosted: Wed Nov 26, 2014 1:36 pm
PostPosted: Wed Nov 26, 2014 2:47 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I have played a vintage Yamaha dreadnought with an adjustable bridge. It sounded terrible.
PostPosted: Wed Nov 26, 2014 4:48 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
One way to do it is put a tailpiece on the guitar, and make the bridge floating.
Typhoon Guitars
PostPosted: Thu Nov 27, 2014 5:46 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
There is a vast difference between adjustable saddles and the old-fashioned adjustable bridge.
Check out the Kevin Pederson patent application and you will see that his invention is very far indeed from being low-end.
PostPosted: Thu Nov 27, 2014 6:39 am
There are different designs , Fact is , if the saddle is in the correct position to begin with you really don't need an adjustable one.
PostPosted: Thu Nov 27, 2014 9:23 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
I have an acoustic where I wanted to improve the intonation. I divided the saddle between the plain and the wound strings, two saddle pieces. I widened the slot for the saddles in the bridge and made a set of ebony shims that locate the saddle back and forth for intonation. The shims match the height and top curve of the bridge and are pretty well camoflauged, but it is easy to adjust intonation by changing the order of the shims. The saddle is still correctly gentle tight in the slot and the weight and materials of the bridge are still standard (otherwise the tone will be affected).
I got lucky and tilted the widened slots at good angles so I didn't have to make any wedge shims.
Gosh it is fun (and rare) to be able to play an acoustic up the neck in tune.
Taking a router to the bridge on an assembled acoustic guitar is the loudest noise I have ever made.
Users browsing this forum: guitarjtb and 19 guests
